Are you sure that your Racin Force board is good and working? It doesnt look like it. Even if you did not have the controls wired up correctly or even if you didnt have the controls wired into the PCB at all you should not see that scrabble.
it was a bad board. I replaced with a working board. It now wants to test the accelerator and wheel and does nothing. So it appears that Racin' force does some kind of POST on the accelerator, wheel and brake. Suck.
