Konami Lethal Enforcers Audio Fix 054986A! Schematic included!
This is my first arcade board fix and I felt proud so I thought I'd post it!
My audio was the stereo-typical muffled sound, low audio and no audio completely! After a few hours and a lot of patience, the fix worked! The first things is to get the black coating off the board which is time consuming. I started with rubbing alcohol and an old toothbrush. From there, I used Carburetor/Brake Parts Cleaner and Lacquer-thinner which I dipped the toothbrush in brushed vigorously the coating off. Only parts of the coating came off which was around the base of the capacitors, oddly enough. The rest I used a razor blade and two sizes of flat head screwdrivers to scrap the rest off. Once exposed, the soldiering iron would not melt the factor solider very well. I used a pair of needle-nose pliers to basically rip the existing capacitors off, cleaned off the remaining black coating then prepped it for re-solider. I began to re-solider capacitors in place trying to avoid the existing traces on the PCB board all together if possible to ensure there would be no breaks in the connections. I've created a schematic for this chip 054986A which should answer most if not, all questions.
But! If you do have questions, let me know! Not too bad for the first post, eh?
