Konami 4 PLayer Harness Question
nerdygrrl
Portland, Maine
So I wanted to use a Konami Jamma harness for a Midway 4 player game, however I realized the Konami edge connector is missing its neg 5 which I believe is needed for the Midway board. Can I just take connectors/clips from another harness and install them in the neg 5 slot on the Konami?
Sure, as long as they are connected to the power supply for -5. The JAMMA harness pins should be the same type.
And you can leave it there, as the boards that don't use -5 typically have an unconnected pad there, so you won't damage a board that doesn't use it...
Thanks. Unfortunately I would need to run the wires as well. Doh. I guess I need to find another harness.
