Know of any 33" chassis boards?
Holleywierd
Donor 2014
Silverdale, Washington
With my pentranic 33" chassis down Im not finding much hardware support for them. Anybody know of a good model I could look and where to buy for my neogeo cab? Thanks!
What kind of Neo cab do you have? Is it a Japanese cab? I've used Kortek, Pentranic and Sharp Image chassis in my Showcase cab, you can actually buy a universal chassis from Alva Amusements, the model you would need is 833H. To order all you have to do is call them, give them your CC info and address and it will show up at your door in a couple of days.
Its a mvs-1 upright. Has made in japan sticker in back inside of cab but wondet if its a conversion as there is no memory card slot on front. The control panel is the same as other standard models. Maybe a generic cab not sure.
I only need the chassis board for now. All sources show the tube should be good but something shorted out my board and wanting to see if cost is low to the arcades value or if should keep poking at the board.
What do these generic boards usually run, dont see a price? Thanks for the link.
Sure thing. Ill get that in a min, yeah mine must be a conversion as the side art was missing and has a straight edge versus that angle in middle of side panel.
Here it is. Disregard the luigi decals.
Yeah, that's a 25" Monitor. The 25" replacement chassis that Alva Sells run about $85 last time I checked which was over a year ago. Well worth it if you're a novice at chassis repair.
It does not look like any American dedicated neogeo cab that I have seen.
Ok double checked, it's not a 25", it's a 33" like the chassis board and my tape measure says. I'll see if Alva sells them.
