I have a Evel Knievel home edition machine. Recently, the feature lights (game over, player numbers, and all the different scoring lights on the playfield) have started to pulse slowly. Not a flicker, they dim and then go back to full brightess in about a five second cycle. They don't all go on and off at once, it's more of a rotating pattern. Everything else on the game works fine, playfield illumination, score, scorebox illumination, tilt, and all other play is normal. The power supply connectors were brown on two pins, and I fixed that years ago and that was for the playfield illumination anyway. All the other pins look fine. I guess that means it's something on the rectifier board, but I don't know.
Any thoughts based on what I've described?
Thanks!
Jeff
EDIT I just checked again, and depending on how many lights are on they will flicker rather than pulse.
Thanks!
Jeff
