Black Matrix
Hey guys,
I kind of had a stupid zaxxon question. How does the LED button work on the top of the flight stick. I mean does it tie into the +12 or 5 volts in the coin door and ground to the leaf switch from the joystick trigger. Does it flash with the fire fire button on the control panel or just from the flight stick trigger. Mine doesn't work and it looks a little butchered. And up until 10 minutes ago, I wasn't even sure they ever worked. Its probably burned out. What voltage does the replacement need to be. Anyone replace it with a different color and what style is it. Or do you know a good source for a replacement. I know its a little thing, but it is a fairly neat feature that would add a little coolness to an otherwise seldom played game in my collection. Thanks in advance.
