Killer instinct monitor
Treydogg77
Donor 2011, 2013
Boone, North Carolina
I removed the Bestech 25"monitor out of my LE cab and put it in my KI 1 cab which needed a fresh monitor! Easy enough till i hooked up the RGB and sync. The colors are real dark and the screen is real blury and rounded. Also while trying to find/connect the correct sync wire a relay on the chassis would click repetitively. The monitor worked fine in the L.E. cab but won't sync in my KI cab. Here is the chassis that I can't get to sync http://forum.arcadecontrols.com/index.php?action=dlattach;topic=61485.0;attach=63580
Any ideas how I can fix my sync prob?
