Kick out hole pauses before kicking out ball
Steelhorse
Gold Canyon, Arizona
Ya on my High-Speed the damn kick out hole sometimes (not all the time) pauses before it kicks the ball out. I lifted the PF and checked the kick out mechanism but I'am new and dont know really what to look for, things look clean and seems everything is there. Like I said it dont do this all the time. It pauses then all the coils "pop" and it kicks out the ball. Thanks. Jeff
Must be a problem with one of the switch(s) that the balls sit on in the trough.
The machine fires all the solenoids when it's doing a ball search, so it kicks your ball out automatically at that point.
Check the trough switches. Go into switch test and see if they are all closed when there are balls resting on the switches. Test them out by putting balls in the trough and watching if the switch(s) closes or not in test mode..
One of the wireforms could be getting stuck in the down position or one of the switch blades could be getting stuck down as well.
Man I think I got the word wrong maybe it's not called a kick out hole, This hole is up on the playfield it's a circle thing the ball can get locked for multi-ball or it kicks it out to set you up for a ramp shot. It's not the ball trough where you plunge the ball to put ball in play. Sorry for that, I'am new and learning so bare with me, thanks.
