Spyridon
My Kick has been displaying some graphic issues. Messed up or shifted sprites in sections and when you move the kickman to the center he disappears. I pulled the board to reseat the ROM chips and noticed that on one of the ribbon cables (J5) the last 4 pins had broken away from the board. Not sure if this is causing the graphics problems or not, but it's probably not a good thing. Anyone know what type of connection that is and where to order it? Also, do you suspect this is the cause of the graphics issues?
I guess they couldn't find 24 pin connectors at the time as each ribbon uses a 20 pin connection and a smaller 4 pin connection.
