Key needed for Pink Panther Skill Stop Slot
saturnkk
Commerce Twp, Michigan
I recently picked-up a Skill Stop Slot and it does not have a key for the inner lock that I believe controls the payout settings.
The lock number is 214... Anyone know where I might be able to get a replacement?
If I can't get a key that will work, is there another way to reset the payout?
Thanks!
Thanks!
I think a Craftsman 18V with a 3/8" inch bit will fit it. (hee hee, just kidding)
Is the lock round ( Ace-type keyed ), single bitted or double bitted ( fort-style lock ) ???
I have LOTS of extra keys laying around. Let me know.
Dave.
for the odds switch I would just replace it with a toggle switch...will function the same as the keyswitch did...
hope this helps..
i know on my machines i did it on (not pink panther but similar) I just removed the box that had the old odds keyswitch on it, removed the keyswitch from the plate, installed the toggle switch and ran the wires that were originally hooked to the keyswitch to the toggle switch....
If you need pictures I can try to take a few later today perhaps...
Josh
