K7502 Compatibility Questions
Torin
Donor 2013
Boise, Idaho
I have a K7502 chassis with matching yoke.
I want to replace it using the same tube but with a K7501 chassis and matching K7501 yoke.
Is this possible or is the tube not compatible?
If I use the K7501 chassis with the K7502 yoke and tube, will I damage the K7501 chassis or will there just be geometry issues?
Thanks for the help.
Torin
Update:
Got a replacement K7501 chassis and its yoke and swapped it out and now have a great picture. So, I was able to use the same tube but needed the matching yoke with the K7501 for it to work. Otherwise it had bad pincushion issues with the wrong yoke.
My first yoke swap. The colors were off and found that the yoke was not pushed up far enough on the tube. Adjusted it and it looks great. I can finally put this one to bed.
