K7500 Wiring Question
wrufai
California
Does anyone know what is suppose to plug into here? It looks like I'm missing this wire and just wanted to know if it has anything to do with why I can't expand my picture horizontally. I already changed the transistor located on the heat sink and had my chassis fully repaired by Buffett. There's something I'm missing and just can't put my finger on it.
that 10 pin header is for the input harness (RGBG and sync). the three you have circled are specifically gnd, and two sync.
And to add to that, depending on your game that part of the header may not be needed that's pin 10,9,8. (1-10) so pin 4 is ground , and so is pin 8. A lot of times you will just see pins 1 to 5 wired R,G,B,Gnd, H,V so it just depends. But no worries you haven't missed anything. !!!
i already sent/pm'ed you a PIC of exactly what you need.
you are missing the width transistor and the heatsink it attaches to.
i also said i had the parts you needed, still do.
Peace
Buffett
Buffett,
It appears that everything is already there. I even replaced the width transistor with a new one and that didn't solve the problem.
Peace
Buffett
your still missing a part.
you still need the bushing that keeps the mounting screw from grounding out the transistor.
the metal tab is conductive on the transistor.
i bet if you remove the transistor from the heatsinc and put in the connector you will have width control.
you can do this for testing only, if you leave it on to long with no heatsink, you will eventually burn up the transistor.
i have the bushing if you need one.
Peace
Buffett
