K7400 wigs out after a few seconds
I have one that did something similar that seems to go away for a while when I play with the pots on the flyback...
I'd try a new flyback.
If you have another K7400/K7500/U2000/U5000 lying around, try swapping the neckboard (if it has the same number on it). There is a chip on the neckboard that can cause some strange stuff like this if it goes bad...
OK, new flyback and it does the exact same thing. I don't have the same neckboard to test out with. Any ideas where to go next? modessitt, you mentioned the chip on the neckboard? Is there a place that stocks those?
Ed
i dunno but heres the info from wg on the neckboard. Used to be you would buy these new, now it just says call:
054A7401-020
Neck Board for Model K7400
Enlarge Image
Call 1 (800) 336-6630 for pricing
Used on: WGM2774-U0TS01K
looks like the verticle is pulling down when it starts in the video.....but my first question is what voltage do you have on the B+ line?
This seems off to me, but I don't know.
One leg is showing 5.6 VDC and the other is showing 19.8 VDC.
One leg of what?
Test the B+ at TP202 - red on the test point and black on the monitor frame...
Oh dang, my bad. I was thinking it was the big white resistor.
TP 202 starts at 110vdc and drops to about 99 when the screen starts freaking.
TP 203 (stated as video b+) stays around 172 vdc
Thanks so much.
Ed
TP 202 should be 117VDC and stay steady.....since you did a cap kit, check r120. It is a 68k reisitor and is known to go bad. Also, check 1.2 ohm resistors by the flyback as they go bad as well.
823 is at 1.6 (Schematic shows 1.8 I think, scan is pretty rough).
303 also reads 1.6 (Schematic shows 1.2)
The resistors are the same based on their banding.
I tested them still on the board though, so I am going to remove them and test again.
Also, the cap that was not replaced via the kit is C729, a 10uf 50v
Ed
Should I replace C729? It's a big boy, 10uf 50v.
Could it even cause this issue? Smalltownguy, what have you done to yours that is doing the same thing?
Ed
