K7400 can't adjust the vertical position enough
edx2x
Michigan
I have a k2574 which is vertically mounted in a game. I can't get the picture to go far enough left to make it look correct.... any help appreciated. I tried a new adjustment board on this one also. I can adjust the size to fill that left 1" but cannot adjust the position correctly
Also have another same model chassis where it worked perfect, went to put on the other tube and it didn't work st all. Noticed the relay was loose and the pad was lifted from the chassis on the leg of the relay going to one of the degaussing wires. Jumpers thst and it still won't kick on. This monitor chassis was working beautifully now it won't come on at all
