Hi all,
I have a recently acquired K7203 (WGE-1972 Hots49A) chassis that I'm having an issue with.
The good news is I get HV and neck glow, however there is no picture. In fussing around with this, I've noticed that the voltages on the crt socket of the neck board get 8V on pins that I think should be ground. I get ~102V and 315V on the pins you expect to get higher voltages on but on all the others they are 8V. Not sure if this helps to identify the problem but thought it worth mentioning.
I have checked all the pots to make sure they work and no shorts. Same with the transistors.
Any ideas where to look when you have HV and no pic?
Thanks for any help.
