sparky5693
I've got a 25'' K7000A that has had a tiny sync issue since it was recapped (a small amount of curl at the top of screen) I decided to pull the connector and double check it today and have since lost all sync. Below is a pic of what I have now.
I also have a question about the proper way for this connector to be wired, as the cabinet was in a non working state when I received it. The connector is 9 pins, and on one side is red, green, blue, ground, and on the far end is one sync wire split into the last two pins. This connector has seen better days, and i'd like to replace it. Can anyone share what size header pins this is for so I can search out a replacement?
