K7000 yoke compatability
Oryk Zinyo
Bremerton, Washington
Are the special Zenith chassis yokes any different than the standard K7000?
I have a standard K7000 chassis and a tube with possible chassis problems with a Zenith installed and I'd like to go to the location and just do a quick swap out if possible.
I just fixed and tested a 25" K7000A chassis on my 25" K7197 tube with no problems...
FYI - I looked at two of these last night (normal and Zenith) and there was a 6 ohm difference on the vertical between the two yokes, but its prob fine.
I guess I should have reported back on this...
The 19" 7000A was a tube problem. It is now fixed and working.
I have since worked on a 25" K7000A chassis that had a blown flyback. I replaced it with a 7193 spare chassis I had sitting around and that cab is fully functional now as well.
