Phetishboy
I have a K7000 with bad tube burn. I have a Sharp tube here with identical numbers, other than the one on the monitor ends in xxxxxxA and the one from the TV ends in xxxxxxB. I assume that though the letters are different, they will still be a perfect match. My question is on the yoke. The one on the monitor has a plastic box on top of it (which the TV tube doesn't have), and the yellow and green wires are swapped in the connectors from one yoke to the other, though the blue and red wires match. The connector is slightly different, but will still fit. Should I try the TV yoke with the tube it's on (and if I do do I need to swap the green and yellow wire) or should I just swap the yoke from the monitor tube to the TV tube?
