Well I had what I thought for the longest time was a board failure in my Capcom Bowling. It turns out after swapping boards around that it is something with the 19" K7000. Here's a quick pic of the distortion (sorry it's a bit blurry) and you can see that it's got waves/distortion near what would be the top of the crt (vertically mounted) that clear up the lower you go. It's already been capped and even a new flyback and I've tried the adjusting it out with even the 50/60hz but nothing seems to effect it. Anyone ever seen something like this? It usually isn't something that happens at first, but after the monitor has been on for a few minutes, but I've also seen it go away with a few power cycles.
