mrbippers
My K7000 is blowing fuses after a cap kit/flyback. Removed bad R103, R104, R105, C33. C36, VR, HOT all okay but removed at the moment. I have a question regarding the T2 transformer.
What should the resistance be across the top and bottom pins (1-2 and 3-4)? I am reading around 50 ohms for 1-2 and 0.8 ohms for 3-4. The low resistance between 3-4 results in the left leg of the HOT showing continuity with the ground. I'm an electronics n00b, so I'm not sure if the resistance between 1-2 will change when the chassis is powered up. If I do need to replace it, where can I find one as I didn't see it on Bob's site? Thanks.
Top of chassis
1 |___| 2
|___|
3 | | 4
Top of chassis
1 |___| 2
|___|
3 | | 4
