M K L
So you have good B+ and the flyback is working.
Heater path from flyback to CRT socket is detailed in the pic I posted above. There are no caps.
Set meter to AC, black probe on big heat sink, red probe on point C. Then move onto D which is the same as J. You already proved continuity on this trace.
If you have another working monitor, check heater voltage at the CRT socket so you can see if your meter has any reliability when measuring this voltage.
