K7000 static, but no neck glow after shorting.
Checking heater voltage at the flyback is OK but to get a proper reading the meter needs to have an AC bandwidth that covers the 15KHz frequency. Most portable multimeters don't do that. Some bench ones do.
This is a K7000A and the heater goes through another resistor (3 in parallel in fact) before going to the neckboard.
Measure resistance from A to J. It should be very low, 2-3ohm. If it reads open, check every point in between until you find where the circuit is open.
If everything tests good, check if you have 12V and 24V. It's more likely that the flyback isn't working at all (no secondary voltages) rather than the heater winding inside the flyback being open.
Hey, so I'm getting roughly 4 ohms of resistance a to j. How do I check the volts?
Check voltage at R90 (in front of the flyback). If you don't have +12VDC there, the flyback isn't working so the lack of heater voltage/neck glow is due to this. If you have 12V, set the meter to AC and measure at point C of the pic in my previous post. In both cases put the black probe on the big heat sink (ground).
Awesome thanks a ton. I'll check this later.
Do you have 130V in (any of) the points here?
And 12V on this side of R56?
B+ (130VDC) is missing probably because the voltage regulator is bad.
Sorry I'm awful at all of this. Does that mean there's a chance the flyback is alive? Is the voltage regulator the HOT? Should I order a part? Thanks a ton for walking me through this.
The flyback is most likely good. It's possible to isolate the VR circuit from the rest of the chassis and test it with a light bulb as a dummy load if you want to make sure it's bad before ordering a new one.
alright awesome, I'll go with just ordering the voltage regulator. Should I get that and the HOT to be safe?
A spare HOT (2SD1398) is always handy to have around but the current one can be tested easily:
Thanks a ton. I put in the orders with the extra hot to be safe as well. I'll get to testing it later, but if it's good I'll just add the extra to my parts. I'll report back when the parts are in and hope it hangs in there! I remember reading about this years ago now with the k7000a and the non-existent flyback replacements, so if we can save it that would be good. As always you guys are the best thanks so much for the help.
Getting 12v at r56 now that I replaced the voltage regulator but still no neck glow.
Also have 130v at those 3 points on the neck board.
If it helps I'm losing voltage right before the heater pins but I'm not sure what I'm supposed to be seeing around that area. The first short I had was on the neck board itself so I'm hoping one of the pieces there is no good
Have you examined the chassis closely for cold solder joints and cracked traces? As in, checked everything in the relevant circuit(s) for continuity where appropriate?
I've looked at it pretty good, but I could possibly go over it again. My thing right now is I'm curious about tracing that voltage from the 3 resistors over to the heater pins.
