k7000 rollover
gabesdad1981
Daniels, West Virginia
I have a k7000 chassis in a dynamo cab , 25 inch screen..My picture is only showing on half the screen and rolled over..The bd in the game is a Galaga 88 which worked fine in my galaga cab with go7...my question is I have a bunch of go7 and some other capkits but none specific to the k7000.. I wonder how many caps are the same???? If any??
Id like to pull the chassis and replace some if not all caps and check for burnt traces.
if its doing the rollover thing i would do a complete cap kit. because all the caps are on their way out.
do it once rather than have to do it again in a month because another cap died on it. they're easy to do and the k7000 doesn't have that many caps any way.
also you can probably adjust the 50/60htz pot and stretch the image. but you will probably have dark lines and bad linearity through out the monitor.
Peace
Buffett
if you get a chance post a picture, would like to add to the k7000 sticky.
id just get a capkit for it and do em all while its out, check the fly for cracks(nows the time), check solder joints, etc. Just git-r-done and over with on one shot.
