I've got a K7000 from a Centipede that started playing blind. The resistor on the side of the chassis is R301 and R302 and the R301 was visibly cracked, glowing, and melted the wires that connect it to the PCB. R301 is a 220 ohm 15 watt resistor. The one that's there now appears to be a ceramic wirewound resistor. When I look on mouser.com, all I can find are aluminum housed resistors (still wirewound) with the same specs. Will this different form factor (aluminum housed work for what is needed here, and how would I mount the secondary R302 resistor (18k 3 watt)?
