Correct that you can't use the 7400 remote as a replacement.
Sometimes remotes may have the same pot values between models, even if for different functions, and you could always remove the remote wiring on your 7000 and install pots directly on the edge as they were on the 19" and some 25" models. Not a perfect solution, but if you're in a time crunch and have the necessary pots already...
