sara teasdale famous poems
Hi guys. I'm working on a 25 in k7000 chassis that smears the red. I gave it a full capkit, reflowed the video header pins, replaced the red chroma transistor (q201), and q1 on the chassis. Both tested good but replaced anyway. Didn't fix it. Replaced the red pots. Didn't fix it. Swapped the neck board with a known working one. No change. Replaced ic1. Nope. Replaced the green capacitor that sits at the front of ic1 which goes to pin 1 and pin 22 because another member had this same problem and that fixed his overdriven red problem. No change. The chassis has a new flyback on it but I didn't know the source so I put in one from APAR. No luck. The tube is good. It's my test tube and I checked it with my bk and tried another working chassis on it just to rule that out.
I'm going to start the my journey through the red circuit. I was hoping someone else might be familiar with this issue though to save me some time. If not, I let ya know what I find.
