Peale
Stop whatever you're doing right now and post a photo of the trace that blew.
I mean the EXACT same chassis it came with. Put it into my Hard drivin, worked, capped it and the such, put it back into HD, worked. Then, put it back in the original frame with original tube, and blown trace.
I'll have to go back and re-read this whole thread... you have swapped chassis/tubes around enough that I don't know what's related to what anymore.-Ian
What trace burned?
It sounds like something shorted.
If you look at the pic of the blown trace, you can see "black char" marks in the middle of the chassis (point of contact?). I also found black marks on the plastic "pcb holder" at the exact same place on the frame where the pcb slides in.
Now, I've tried soldering traces together before (4900 broken neckboard thread, thanks again Cliffo!!!!) but, I had a very hard time getting the solder to stick. Any tips on soldering without pads????
Thanks again
Will "ohm out" the yoke tomorrow. However, I'm at a loss on how to properly perform this procedure. Where the hell do I exactly put the probes???? And once I get the numbers...What on the chassis determines if it will work with that yoke??
Thanks again
