Pins on the yoke header pinpads test fine using continuity. Followed green and yellow wires to other side of the board. did continuity test - works.Make sure your horizontal yoke header pin pad(s) aren't broken and have continuity to the traces to and from them. Simply reflowing D18 won't cause it to go from working to no heater voltage.
You look like you missed a part.
for all the doom and gloom about white knob flybacks, which I'll echo once more is just something perpetuated by people that literally sell flybacks, there's a metric shit ton of these in actual arcades still operating in that condition. not people's basements or bathrooms, but in commercial settings where they were intended to operate for many hours a day.I think those are the yoke header pins, I thought the same thing when I first saw it lol.
@boy141 When you say: "D18 black band is facing away from the metal heatsink." does that mean the black band is closer to the "middle" of the board, or closer to the outside edge? Just to clarify.
D18's solder pads look ok to me. Just an FYI, diodes short not go open.
It sounds like the flyback is not energizing at all. So yeah it would be nice to be able to test a flyback, and you can use a ring test, but that requires a special piece of equipment.
So, this could be a couple things:
If this was in my possession, I would (in this order):
- Flyback is bad (this is very suspect because of the issue you had before, the original white knob flyback is installed, and ya if it's cracked it's on it's way out. If you have another flyback this would probably be a quick easy cheap test).
- Flyback is not receiving reference voltage because of:
- Xray protection pot. It's right underneath (in your pic) the green and yellow wires by the vertical IC heatsink. If this got bumped, broken or something it would shutdown the monitor and give the symptom you are having.
- A lost connection from your B+ supply to the flyback primary.
-Pat
- Test the b+ pot, probably by removing it out of circuit, trying to remove the glue if I could. If I couldn't, I'd be replacing it.
- I have extra k7000 flybacks, so I would just substitute a new one and re-test.
- Check for missing connections on the b+ rail to the flyback primary.
I just subscribed to the mecha2001 youtube channel. Unlike mecha, mecha2001 knows what he's doing.for all the doom and gloom about white knob flybacks, which I'll echo once more is just something perpetuated by people that literally sell flybacks, there's a metric shit ton of these in actual arcades still operating in that condition. not people's basements or bathrooms, but in commercial settings where they were intended to operate for many hours a day.
also K7000s have fixed voltage regulators, there is no B+ adjustment. that's the shutdown pot. while it may be true it could've gone bad, this monitor was actually running before it got monkeyed with about 8 times too many.
while it's true the K7000 is like the Chevy 350 smallblock of monitors, they do require a fair amount of work to make right.
mecha is a terrible person. people say he's mean.I just subscribed to the mecha2001 youtube channel. Unlike mecha, mecha2001 knows what he's doing.
