K7000 neck glow black screen.
Buakaw
Donor 2017
Houston, Texas
Hi all. I've been through hell and back with this 25" k7000. I had it working for about a week after replacing the flyback, HOT, VR, filter cap, c38 and it died again. I'm currently getting neck glow, the fuse is not blowing, nothing on the screen, and I'm getting 170v on one side and 109v on the other side of the giant resistor on the side. I know this is too high. I found the solder from the flyback to the neckboard had come loose. When I fixed that it smoked at the giant resistor on the side and I lost neck glow and it seemed that the crit safety cap (c36?) went out. I had another k7000 with the og 4 legged type. It tests good so I swapped it out. I'm still getting neck glow and black screen. Could I have killed another flyback with that loose connection? The VR still tests good. All that I've read leads to a bad VR but it still tests good. Any ideas? Thanks in advance.
Here's an update. So the VR tests bad after all. Could the passing of the crit safety cap killed the VR? I'd hate to replace this VR just for it to blow out again. Any ideas?
