Bullwinkle
K7000 - missing cap and another one not in the right spot...
I'm recapping a non working K7000 monitor for a friend (will be installing a new flyback and the big transistor as well). Almost done, but now I've run into the two largest caps in the capkit from Bob Roberts.
Bob says C50 should be a 1000uf 25v and C40 should be a 2200uf 35v
The board has the 2200uf 35v at C50 and C40 is empty. There is also a jumper on the back of the board that runs from one of the legs of the 2200uf cap at C50 back to the blade that fits though the board to which the big transistor is mounted.
I know a lot of times boards are modified, but the cap completely missing next to the flyback is a new one to me.
Should I keep it as it was or put the caps per Bob's Kit.
Any suggestions are greatly appreciated.
Thanks,
Tom
Thanks,
Tom
