Zoma
When I was installing a new cap kit on my K7000 there were two caps near the flyback I had an unbelievably hard time getting to. I had to unscrew the heat sink (I think that's what that is? The metal piece over the flyback) and bend it to the right just a bit to fit one of the caps in correctly, and in doing so I think I damaged the IC2 chip (correct me if I'm wrong on the terminology) that's attached to the metal piece. It's a chip with three pins directly soldered onto the board in a triangle shape just to the right of the flyback. I tried reflowing the solder joints and wiggling the chip around; seems to not work, but I'm fairly certain I messed it up. Any ideas? Attached is a picture of the screen post-cap kit. Thanks in advance.
