K7000 horiz streaking/tearing
looks like your wight balance and contrast are out of adjustment.
center all the pots on the neck.
center your contrast and brightness pots on the chassis.
adjust your fly then your contrast and your drives on the neck.
if that does not help, the tube looks like it could use a rejuve.
Peace
Buffett
The tube might need a rejuve, but it looks okay color-wise with a different chassis. The other problems are unrelated to the tube. I tried adjusting the pots, but the image continued to tear and smear even with screen & contrast set to make an extremely dim image.
Here's another photo: http://i.imgur.com/tRAaY.jpg
It's almost like it's losing horizontal sync.
i would verify that your H-Hold and H-Pos pot are not cracked and that you are only using pin 10 for synk.
also i had this similar issue earlier today make sure your VIDEO ground is making proper contact in the connector and on the chassis.
i had similar problems today with my test station and it was a bad ground wire it was only connected by one strand of wire.
i have to inspect the wires on a regular basis due to the constant plug and UN-pluging of the connector when testing allot of chassis.
Peace
Buffett
The pots seem fine. Adjusting them adjusts the position and hold, and the image doesn't jump around. Should I be testing them in some other way? Metering?
Sync should be fine. The MVS has a single connector, the K7000 has a single header, there's no way to put it in wrong. Another K7000 chassis (with other problems) syncs fine in the same setup.
This is the wire that goes from the neckboard to the frame ground, yes? It's connected just fine.
Here's a video, which I hope better illustrates what's going on: https://dl.dropbox.com/u/6120067/K7000.m4v
1. Left edges of things are much brighter than the middle/right.
2. Upwards-rolling bars in the image.
3. Horizontal tearing.
What should I be looking at?
from the video it looks as if you are running a 19" chassis on a 25" tube??
no i am talking your video ground.
red
green
blue
GROUND <------- here
synk
synk
KEY WAY
GROUND <------- or here
synk
synk
make sure one or both is connected.
and for giggles verify your synk wires also.
i have to re-pin mine allot because of all the chassis i repair, it takes a toll on where the wires are crimped to the pins.
Peace
Buffett
No, I was just fiddling with the adjustments to see if it changed anything. It will fill the screen when adjusted properly.
red
green
blue
synk
synk
KEY WAY
synk
synk
I'll double-check, but I am very certain it's connected correctly.
