nate1981s
k7000 focus good 6 seconds then slightly not for 6?
Original monitor in a mortal Kombat cab. 25" wells gardner k7000
I fully recapped a few months back. After about 5 hours the focus was way off and it appeared the flyback was failing. I replaced the flyback with a new one. Everything has been fine I thought but every time the character screen in attract changes if you look at the text it is in focus for a around 6 seconds then the focus blooms just enough that the text is not sharp anymore, screen changes to another character and the issue repeats. I should note that I have noticed that the tube has a brown tint to it suggesting a lot of hours. Contrast I have set low and brightness and it still happens. Tube does appear somewhat weak.
here's what I think,
Possible bad new flyback
Worn tube?
Should I replace the HOT or other IC? I bought the full kit from Chad so I think I have some.
thanks,
nate
Worn tube?
thanks,
nate
