K7000 flashing/popping Issue
rydin4life
Pennsylvania
19" k7000 just recapped and installed a new flyback. Hoping powering on, i get rhse flickers/pops. Anode connection is clean and secure. Could it be a faulty so ket on the neckboard?
did you connect CRT ground?
also the brightness is too high. and apparently you have the horizontal and vertical halves of the yoke plug backwards.
Yes..gound is connected. I do need to swap the yoke plugs, but grabbed thr video before I pulled the chassis back off.
Following up on this - I swapped the neck board with another and the issue went away. I reflowed all solder on the neck board, paying special attention to the socket - re-installed, and all is well so just some bad solder joints fortunately.
