k7000 dead, bad fuse caps leaking, a couple of questions
I read through cadilliacman's threads and bob roberts as well.
I tested the resistors suggested by bob they came up on my multimeter as 475, 475, 530, 525 holding steading does that mean they are good?
Also tested r103 it came up 1475 or so holding steady, good?
In the picture I am listing both the black caps are oozing brown goo from the bottom and the white square (forget what it's called) is loose. I looked at the bottom and either it was blown from the traces or just got popped off. solder is still intact, I am going to go check it out in a minute.
basic cap kit and flyback replace sound like enough on this one?
