Remember, the horizontal output transistor and the voltage regulator require a mica insulator behind them along with a smidge of silicone heat sink grease.
The suckass part about this chassis Dylan is that it most likely blew your brand new hot.
For the future, you can test a 25" K7000 chassis on a 19" tube by swapping out the 25" neckboard with a 19" neckboard. The picture will run off the screen but it will produce a pic. that confirms whether or not you fixed it.
