TRK
In Tempest - is this a board problem? I checked all Transistors good on chassis, checked resistors diodes etc on deflection board as well. Reflowed the header pins etc.
This will go from that and revert back to spot kill, then a few minutes it comes back, then spot kill.
Could this be an x y problem from the board? I also checked molex connectors from board and voltages there change quite a bit.
B+ is good, I am getting the correct voltages on Pin 1 and 5 as well so its hard to use chart.
