Bullwinkle
Does anyone have a cap map or can someone point me to a manual for a K5501. I've been told this WG model is the same as the 4900 series but it's for 25" tubes. I started going over the caps on the board and noticed that the values of the first dozen or so caps were identical, so I just used the 4900 cap designations as an ordering tool... now I'm finding some of the bigger caps near the flyback have a substantially higher voltage rating than the ones I ordered using the 4900 manual and the cap at 313 is a 47uf 160v cap in the 4900 manual, but the one onboard was 100uf 160v (this is the only cap that had a different MFD value)
Now the board obviously has been re-worked before, but I'm wondering if I the previous technician simply used what he had and went high on the voltage values for caps or if the values in the board are spec for a 5501.
Any help is greatly appreciated, thanks.
-tom
-tom
