K51XX WG 25" Monitor
wmacmonagle
Donor 2012
Rosamond, California
I had purchased Med Res Monitor and plugged in iCade and it show werid picture but tested with paperboy and it works perfect??
Is there any switch that I can flip and change Med res to STD Res on Chassis or so?
Thanks..
wmac
K51xx? Well, you either mean:
1) a K5500 - which is standard res
2) a K5515 - which is medium res
3) a U5000 - which is dual res and has a connector in the middle of the chassis to select standard or medium res.
the fact that it works with Paperboy currently says it is either #2 or #3. If it is 19", then it is most likely #2...
Yes its k5515 i believe.
Drat.. i guess ill just sell it! =)
