There are two ways to flip an image without changing any wiring or connectors:
1) If your game board has a dip switch option for image flip, then just flip the appropriate switch and you're done.
2) Pull the monitor out, rotate it 180 degrees, and put it back in.
Otherwise, all you need to do is pull off the yoke connector, cut the connector between the blue and yellow wire, then rotate each half on the pins they are currently attached to. This will change the yoke wire order from Red/Blue/Yellow/Green to Blue/Red/Green/Yellow. Of course, you're problem may lie in the fact that someone has already done this, and you just have to change it back...
