so, i just capped the 4900 chassis in my satan's hollow, and am getting a great pic. problem is, i am having trouble centering it. even with the jumper on the down position, i still have a larger gap on the left side then on the right side of the screen.
also, the leftmost 1/4 of the screen vertically is squished, i.e. slightly narrower than the rest of the screen is as well. this is most noticable in the attract mode, as you can see the first s in satan's is narrower than the right s. any ideas there? if i mess with the vert hold and size to get a smaller picture, everything is the same size vertical width wise, however when you try to fill the screen that is when the left size gets squished.
i'm thinking that if i can actually get the vertical to center it should correct the narrower side issue.
