The trick is to try to read the tube # through the vents before you buy the tv. Print out the tube list I posted here and then when you read the tube # you can check the list to make sure it's a cr-23 (what you'll want for most monitors). You'll want a flashlight to see through the vents. Sometimes that's not good enough though. I frequent the goodwill outlet and I bring little wire clippers so if I can't read the tube # I can cut out one of those vent bar things to see better. Obviously not something you can get away with at a garage sale, and even at the goodwill outlet I have to be careful not to be seen. I don't buy a tube unless I know it'll work.
