sfluter
I've read as many posts as were here on the subject, but any further help would be appreciated.
I just finished swapping a tube and was going to try to work out the convergence issues. However, when I turned it on there was immediately some smoke from the area around the yoke connector and width coil. I shut it down quickly and then went to get a better light so I could see where the smoke was coming from exactly. When I switched it back on no more smoke, but there is only a thin line of video running vertically (monitor is horizontal).
I have:
switched out the width coil
tested B+ (128.8)
visually inspected and reflowed solder around the yoke connectors and width coil
tested resistance across the yoke's, it is normal
Any help appreciated.
I have:
tested B+ (128.8)
