CocktailDave
Hello there!
Noob with my first post here.
I have done a ton of reading prior to my first attempt at a tube swap. I swapped tubes on a K4914. I used the yoke from the Wells because the ohms were low on the TV tube. I have a really nice picture right out of the box. I haven't even adjusted the yoke. My problem is what I assume is foldover on the vert. I pretty sure it was there before I swapped tubes. I swapped tube because of the severe Gauntlet burn.
So is this classic foldover and will recapping most likely fix it?
Thanks for your help!
Dave
Dave
