K4600 Video Interface board information
I would not worry about any sync transistors.
You should replace TR201 and TR202 in the black level circuit first. I have seen those fail over the years and they are dirt cheap to replace.
K. I'll hit those up ASAP and report back. Thx!
The 2N3904 transistors are the world's most common and cheapest transistors out there. Everybody stocks them: Mouser, Jameco, Digi-Key, Radio Shack, etc.
You can even buy them on ebay.
No dice - still not working after replacing 201 and 202
Check zener diode ZD201 (3.9 volts @ half watt).
Check all the resistors in the black level circuit: R204, R204, R206, R220.
Check electrolytic capacitors C201 and C202.
Will do but, on the parts list/layout you have in the thread, it lists the 6.8v Zeners and I picked those up instead. Can the larger voltage be used without issue, kinda like larger voltages on caps can?
EDIT: All resistors (203, 204, 206, 220) are within tolerance but 220 is the same as 203 - a 1K resistor. Same on the other boards I have as well. Schem shows 680. Caps AND Zener (proper one used) replaced to no avail.
AND the black pot tests good on the resistance check with a multimeter (changes when turned).
As of now, I've replaced on this P317 that has the black and horiz pots on the side:
TR201
TR202
ZD201
C201
C202
Black pot tested good. Resistors in black circuit test within tolerance with one end removed from board as to be out of circuit.
Also replaced TR206 and TR209 hoping to get at least green back if those were bad - all no change.
Tested my one known good card on two chassis - works. This bad on tested on same two two chassis - no workie.
And you're remembering to plug in the cable from the neckboard to the video interface board?
Is there a problem with the white connectors on the bottom of the P317 boards?
Yes, that's connected.
They've been reflowed and test good for continuity. . .
A friend just bought a box of a dozen video interface cards for the 4600 monitor. I went through them and repaired them but came across an unusual one. This one is a P298 board, but with a real nice pot attached to the edge of the board and a nice knob on it. It's too good of a job....looks like the factory might have done this. Why couldn't ALL of the video interface boards have this "easy-to-adjust" black level pot installed originally?
when you click on the links...
I thought I would start a thread detailing the various "Pxxx" Video Interface boards used in the Wells-Gardner K4600 (19 inch) and K4700 (13 inch) color video monitors.
First up is the P297 (composite negative sync) board. Pictures of the front and rear of it.
Parts list:
http://www.arcade-museum.com/manuals-monitors/Wells Gardner P297 parts list.pdf
Schematic:
http://www.arcade-museum.com/manuals-monitors/Wells Gardner P297 schematic.pdf
Board Layout:
http://www.arcade-museum.com/manuals-monitors/Wells Gardner P297P302 layout.pdf
Links fixed
Parts list:
http://www.arcade-museum.com/manuals-monitors/Wells-Gardner-P297-parts-list.pdf
Schematic:
http://www.arcade-museum.com/manuals-monitors/Wells-Gardner-P297-schematic.pdf
Board Layout:
http://www.arcade-museum.com/manuals-monitors/Wells-Gardner-P297P302-layout.pdf
