K4600 Too Wide
FrizzleFried
NAMPA, Idaho
The K4600 I have in my Pac is too tall (wide)... the width coil adjustment does nothing. The score is 1/2 off the screen at the top and the fruit is 1/2 off the screen on the bottom. Is there a cap hack or something I can do to fix this issue?
Uh... um...
I thought that was only for K7000/G07...
Yeah.
I'm curious if you ever got it working right. I did a cap kit and a tube swap with a TV tube that had almost exactly the same H/V readings on a ohmmeter. The picture is awesome with no convergence issues, but I just can't bring it in to the edges with the horizontal width coil. Did you ever change out the Poly cap at C615? Thanks!
I just did this with a K4900 that wouldn't adjust enough with the width coil. Changing the poly cap worked great. I'm sure it is similar with the 4600.
From my recollection I simply swapped in other cards from another 4600 I had sitting on the shelf...
