K4600 placed vertical has uneven colors?
MadPerry
Rochester, New York
So I'm doing a Raiden cab restore and it needed a monitor. I have 2 k4600's so I placed one in the cabinet in the vertical position. Powered it up and noticed that colors were uneven across the screen. Set it aside to look at later and put in my other k4600 in the vertical position. Got the exact same result.
I then tested both of them in their normal horizontal position and they both look perfect.
Last, I took a K5600(that I know works fine vertically) and tested it vertically. It worked perfect.
Can anyone shed some light on why my K4600's won't display properly when placed vertically? I understand they weren't intended for vertical mounting, given their frames, but I'd like to make it happen if possible.
They will need to be manually degaussed.
Thanks for your reply. I thought it might be a degaussing problem, but they both have working coils so why would I need to get a wand and manually do it? Is this something I would need to do every time I turn it on?
