K4600 l351?
low failure rate, if you need one canibilize one from another card or just use a differnt card.
Unfortunatley I know all this. But here is my situation... I had one that someone had obviously F-ed with and broke the set screw....
So I was going to pull one off another card I had on the list to rebuild, and the brittle little bastard roke apart when pulling it out of the card....
Now I have TWO cards that need L351s!! :(
Anyone know of a source besides off another card?
Which card are they on I might be able to help.
It is on the V/H card.....its looks like a little square box with a pot in the middle of it on the top....inside is a coil...it is the rough adjustment for the sync...
Ok, I went down and checked my parts stash. I would rather just sell whole cards than try to desolder what appears to be a brittle component. Just start over with these cards.
I have several complete parts cards with assorted problems (most have vertical collapse or a cracked PCB) . $10 each
1 tested working card. $25. Tested today.
Let me know.
Sweet,
PM coming your way....
Let me know.
