K4600 double image
doomed
New Jersey
Just had a k4600 rebuilt and it tested fine. When installed back into my Galaxian cab it has a double image. Could it be the sync ? I adjusted basically every pot on the chassis.
the metal box on the x/y card that fits the flat head screw driver will need to be adjusted. that should fix your image.
here is the way the rgb, gound and sync have to be hooked to to this card.
Does anyone know the video wire colors for an early Galaxian ? I cant seem to figure the wire color to the right pin. My connector is the following.
1. w/br
2. green
3. empty
4. red/w
5. yellow/blk
6. orange/red
The Galaxian manual has the following:
1. w/br
2. yellow/blk
3. empty
4. red/w
5. green
6. orange/red
I cant seem to get this picture to sync. I have the P297 board and the 205 pinout says,
1. Video green
2. Video blue
3. empty
4. Video red
5. ground
6. Composite negative sync
