Jvc s75-94v-0 ??
P-F-PIN
Donor 2016
Gloucester, Ontario, Canada
Does anybody know anything about this chassis?
Number day: JVC S75-94V-0 3A125V
I can't find JVC chassis anywhere.. I shows a vertical collapse and I wouldn't mind getting a recap kit. Of course if it comes to it I'll look at the existing capacitors and buy them individually..
You have the Electrohome G07 chassis. The world's most common monitor found in many classic video arcade games.
Made in Kitchner Ontario.
Ha! Well wouldn't you know it!! (I guess you did!). :) I thought I did the rounds of photos out there...
Thanks Ken, much appreciated. Will be sending out for a cap kit after I look it over thoroughly. there are some burnt marks on the yoke controller..
Cheers and thank you!
It's generally accepted that if you recap a G07 you change the flyback as well.
That is the idea, as an experiment I left the original flyback in my super pacman after recapping about 10 years ago. IT just did a 3 day show and is still running strong, it might never go bad!!!!
The problem with g07's I've heard isn't necessarily that the internals go bad rather the shell cracks and sprays hv. You got a good batch other people dont and the case fails. I'd replace.
